Beanies for HTV
cook_58
Re: Beanies for HTV
Post by cook_58 »
Hi Guys I am looking for beanies that are decent for pressing HTV on to.
Does anyone have any good makes or brand to go for or what styles work best?
cheers
pw66
Re: Beanies for HTV
Post by pw66 »
Result have just launced a new thinsulate beanie with a self coloured twill patch on the front, ready to press or embroider. Beechfield do a couple of similar styles, though not thinsulate lined.
cook_58
Re: Beanies for HTV
Post by cook_58 »
Pw66 thanks for the post, I've seen a few beechfield beanies, problem is im not sure what ones too use.
Any pointers one what ones to go for?
I shall check out the result ones too.
Sent from my SM-N960F using Tapatalk
Re: Beanies for HTV
[ATTACH=CONFIG]5957[/ATTACH][ATTACH=CONFIG]5958[/ATTACH][ATTACH=CONFIG]5959[/ATTACH][ATTACH=CONFIG]5960[/ATTACH]
BTC sell them
vB_ID:5960
vB_ID:5960
vB_ID:5959
vB_ID:5959
vB_ID:5958
vB_ID:5958
vB_ID:5957
vB_ID:5957
cook_58
Re: Beanies for HTV
Post by cook_58 »
Awesome, i did think it was be those type, just wasnt 100% sure. Thanking you!
pw66
Re: Beanies for HTV
Post by pw66 »
The Result ones are probably not in stock yet, but thinsulate lining aside, are essentially the same. Unless there is a big price difference the lining will give them a slight edge if selling for workwear.
cook_58
Re: Beanies for HTV
Post by cook_58 »
Awesome, i'm doing little bit of work wear here and there, will be good to add to it.
Quick question, use pencarrie to buy things in, do you know if they will do the result ones?
Or of any other site that are the same/similar to pencarrie i can get set up with.
Thanks.
pw66
Re: Beanies for HTV
Post by pw66 »
Pencarrie stock both Result and Beechfield.
cook_58
Re: Beanies for HTV
Post by cook_58 »
Awesome thanks.
