Beanies for HTV
Re: Beanies for HTV
Hi Guys I am looking for beanies that are decent for pressing HTV on to.
Does anyone have any good makes or brand to go for or what styles work best?
cheers
cheers
Re: Beanies for HTV
Result have just launced a new thinsulate beanie with a self coloured twill patch on the front, ready to press or embroider. Beechfield do a couple of similar styles, though not thinsulate lined.
Re: Beanies for HTV
Pw66 thanks for the post, I've seen a few beechfield beanies, problem is im not sure what ones too use.
Any pointers one what ones to go for?
I shall check out the result ones too.
Sent from my SM-N960F using Tapatalk
Re: Beanies for HTV
[ATTACH=CONFIG]5957[/ATTACH][ATTACH=CONFIG]5958[/ATTACH][ATTACH=CONFIG]5959[/ATTACH][ATTACH=CONFIG]5960[/ATTACH]
BTC sell them
BTC sell them
- vB_ID:5960
- prod_b446_136177.jpg (90.72 KiB) Viewed 10 times
- vB_ID:5959
- prod_b445_128250.jpg (92.89 KiB) Viewed 10 times
- vB_ID:5958
- prod_b443_128241.jpg (95.41 KiB) Viewed 10 times
- vB_ID:5957
- prod_b440_128240.jpg (93.34 KiB) Viewed 10 times
Re: Beanies for HTV
Awesome, i did think it was be those type, just wasnt 100% sure. Thanking you!
Re: Beanies for HTV
The Result ones are probably not in stock yet, but thinsulate lining aside, are essentially the same. Unless there is a big price difference the lining will give them a slight edge if selling for workwear.
Re: Beanies for HTV
Awesome, i'm doing little bit of work wear here and there, will be good to add to it.
Quick question, use pencarrie to buy things in, do you know if they will do the result ones?
Or of any other site that are the same/similar to pencarrie i can get set up with.
Thanks.
Thanks.
