Couple of problems desperate for help
malcassy
Re: Couple of problems desperate for help
Post by malcassy »
Hi
Have been trying to sort one problem out and now i have two.
Back in January i bought a new Ricoh 3110dn printer which was part of a start up package drom dye sublimation supplies. it came with sublisplash ink and everything was working well until a few weeks ago, i started to get faint banding om my prints which gradually got worse, did several cleans, flushes and print allignment but still the same. So i replaced the cartridges with refillable ones which worked for a few prints then banding came back again. few more cleans and flushes and finally it started to clear up with just a few very faint lines. Did one more flush but it never finished the process. Now its stuck on error sc 20252 and every time i switch it off it tries to start up but then after 2 or 3 mins it goes back to the error.
The other strange thing is when you go through the menu now the option to do a nozzle check clean etc isn't there.
Spoke with dyesublimation supplies today and they told me its not under warranty as i used different ink in the printer, even though i used it after the problem first started.
Does anyone know what this error means and is it possible to fix it?
Problem 2
As i need a printer with limited funds i bought a second hand epson 1500w today on ebay which i collected this morning was told it had only done approx 50 pages didnt see it printing but they had done a few nozzle checks which all looked fine. Got it back to work and spent ages trying to set it up with an icc from cityink printed a couple of pages which were awful colours and now 3 of the print heads dont seem to be printing at all. Would i be better to buy new refillable carts for it and bin the ones in it and replace the ink? ive had a bad day and hoping someone can shine a bit of light on my issues, i have several jobs i need to get done and now two duff printers.
pw66
Post by pw66 »
Keep trying with the cis. Make sure that all of the cartridges are full of ink. The ink can drain back from the cis if the level is too low, but be careful. If you raise it too much you risk the reverse problem and could flood your printer.
You will need to install a ICC profile to get the colours right. Your ink supplier should mhave sent one.
malcassy
Post by malcassy »
Thanks for the info i came into work two hours early and have got the epson 1500 almost printing perfect still a few bits missing from the nozzle check.
Was hoping to get the ricoh working as that seemed to print much better.
malcassy
Post by malcassy »
one thing i do seem to be struggling with is the icc for the epson as the info that came with the profile seems to be for a newer version of epson software so some of the things im supposed to select or switch off i can't find,
Are these the correct settings in the printer
vB_ID:5771
vB_ID:5771
pw66
Post by pw66 »
vB_ID:5770
vB_ID:5770
Screenshot (7).jpg (19.14 KiB) Viewed 367 times
malcassy
Post by malcassy »
Thanks for the info i have managed to get the epson printing now, not sure if it's as good as the ricoh but at least its doing something :)
