It wont let me change the cutter pressure without freezing. I have to switch unit off and restart it and it is stuck on the vinyl flex settings. Anyone come across this before? Any input greatly appreciated.
Happy New Year.
Tony
Its worth a try - will do it later.bms wrote:Don't know the technical answer, but try pointing a fan heater at the control panel for, say 1/2 hour and see if that might remove any moisture build up or warm up some contacts. Nothing to loose anyway.
Although it might be a daft idea, our till started playing up on Christmas Eve and despite dismantling it checking contacts etc it still won't work. Several forum threads suggested the heater treatment and today it started working again!!
