Banner printing - Eyelets etc.
Re: Banner printing - Eyelets etc.
Been a few years since I did banners etc. but we're getting a new latex printer installed next week so starting wide format again.
Already been asked for a couple of banners so would appreciate any advice on pricing etc :-)
I'll need to get the eyelet machine etc. I see expensive ones with the suppliers and cheap ones on eBay. Do you get what you pay for with one of these or does a cheap machine do the job just as well?
Hi Justin
I got mine from Sign Making Supplies. Been pretty good and would recommend it. If you are going to be doing a lot then consider bolting the thing to a bench which will make it easier.
Was thinking about a latex myself, which one did you get?
P.S. I get my material from Graftype, its about the cheapest at the moment depending on how much you buy :-)
Thanks Simon, I was just looking on their site.
I've gone for the HP 115 with cutter. Should be a useful machine.
Also been looking on Grafityp as they've always been recommended but I've never really bought from them.
StellaD
Post by StellaD »
We use the KTP model shown in the picture at this link:
https://user-2oyvvah.cld.bz/DTP-Full-Catalogue/54-55
DTP Supplies is the supplier - very friendly and specialists in eyeletting.
This model uses self piercing eyelets. You drop each side of the eyelet into the holder on the machine and a single press of the pedal makes the hole and sets the eyelet in a single movement.
Much easier than trying to use a hand tooland portable enough to be shifted into a corner when not needed.
Thanks Stella :-) What price are these free standing models? Do you find this easier than having a desktop model? I would have thought having the banner flat on the desk and moving the machine around would be better? I guess you just wheel this around the work surface if it's the right height?
StellaD
Post by StellaD »
It's way easier than a desktop job for us.
We drop the banners on the floor and feed them through as we eyelet - print the eyelet marks when you print the banner.
Quite quick when you get into the swing.
Can't remember the price but maybe around £125 + VAT though goodness knows what the carriage is "overseas" :biggrin:
You have floor space??? Now you're just showing off!
Uhm, overbloodyseas.....
Mine was never bolted in a fixed position or on a solid table but I do think it would be a lot easier to do it that way. Moving the machine around was just a pain in the neck, far easier to move the banner.
pw66
Post by pw66 »
Also consider the self adhesive tabs. Just as strong when used in conjunction with clear reinforcing tape ( possibly stronger because they dont pull out like eyelets do).
Bit more expensive, but they look nice with digital banners and are quicker than hemming and eyeleting.
https://signgeer.com/product/banner-cle ... tabs--1110
I had a quick look at similar tabs yesterday, initially dismissing them but looking at these they do look very good. I like the idea that they don't interfere with the print and are somewhat stronger.
I guess most folk expect the banner to be hemmed with eyelets so it's just changing perception.
