Problem with T-shirt press
louise1977
Re: Problem with T-shirt press
Post by louise1977 »
Hi I have bought two Adkins flat bed presses it was a job lot, Really wanted Adkins has told they were the best even though these are quiet old. All though one doesn't work has HEAT FAULT shows on the controls after a short time and when you come to setting it nothing happens then other times it will. Has anybody any ideas what it could be. Also the other machine everything seems great except the finished results. The man who I bought it off told me to set it at 170 for 20-30 seconds for t-shirts but ive at to increase that to 60seconds and the outcome of the image is still faint. Ive been doing mugs for a while and this is my first go at T-shirts so ive been using an old shirt from my wardrobe im hoping the reason for this is its not suitable for printing on. The press down mechanism has been tampered with but it does seem relatively tight and in good working order. Any help or suggestions would be greatly appreciated. Thanks
Quinsfan
Post by Quinsfan »
Are you trying to sublimate the shirts? Are they polyester?
Just as a trial, I'd try 180 degrees C for 60 secs as a starting point for sublimation onto polyester.
louise1977
Hi yes im trying to sublimate but the shirt isn't polyester. The shirt however is very old and has been washed many many times. I just keep trying a small emblem on it until I can get a decent result before I use some new ones I have. Polyester is the material modern football shirts are made of I think ?? Thanks
louise1977
Hi its not polyester im not sure what it is. It is however very old and has been washed many times.
Quinsfan
Post by Quinsfan »
A very basic rule is you can only sublimate onto a polyester garment.
logobear
Post by logobear »
get a heat gun or strips on your press.
generally, sublimation needs at least 180c - 200 better.
it might transfere onto non poly, but will always wash out.
sub only works on poly.
Adkins do an excellent full service, returned LIKE NEW - costs £250 + carrage, includes all parts except control board
louise1977
Thanks that's brilliant. Has I said ive only done mugs and im just starting out on shirts. Has for the Adkins service that's well worth knowing. Thanks again.
logobear;124595 wrote:get a heat gun or strips on your press.
louise1977
Thank you this old shirt probably isn't polyester then. That's why im failing. Thanks again
Quinsfan;124594 wrote:A very basic rule is you can only sublimate onto a polyester garment.
louise1977
Just found out shirt is cotton
louise1977;124597 wrote:Thanks that's brilliant. Has I said ive only done mugs and im just starting out on shirts. Has for the Adkins service that's well worth knowing. Thanks again.
