Colour transfer too light
A11kns
Re: Colour transfer too light
Post by A11kns »
This is probably a sill mistake by me.
I've printed a coaster for a friend and it turned out perfect
I then pressed a mug on the same printer same settings and it turned out like this
Much lighter. There is more ink left on the paper then there was on the paper used on the coaster.
I tried again with different setting on the press and still the same...
First press was 185deg for 180 sec
Second press 180deg for 210 sec
I'm using a signzworld press. And ricoh SG3110DN with sawgrass ink
Any ideas please?
Reg
Post by Reg »
Your'e printing on two different materials with different finishes
A11kns
Post by A11kns »
I did think this would be an issue, but can I get it closer to each other?
Reg
Post by Reg »
You could darken the pic in your software before printing it'll be trial and error till you get near the same
A11kns
Post by A11kns »
Problem is I don't think thats the issue. When I look at the paper after pressing there is less ink left on the coast paper and more on the mug paper!?
A11kns
Post by A11kns »
I've tried darkening the image but it's turned out the same I increased temp and time but I think I over cooked it as the black was more brown. But the brown just hasn't come out darker?!
mrs maggot
Post by mrs maggot »
ceramic setting on the printer software ??
A11kns
Post by A11kns »
mrs maggot;118131 wrote:ceramic setting on the printer software ??
Good call that!! I have it set up on my mac but I'll see if I have the ICC profile to use
A11kns
Post by A11kns »
Is there a profile / setting I can use on the mac?
