Heatproof tape on mugs
Phil47
Re: Heatproof tape on mugs
Post by Phil47 »
Hi everyone.
I am a newbie, I have used quite a few mugs getting the pressure and temperature right on the mug press, but I am now having a problem with the heatproof tape marking the mugs. I bought my mug press from Mega, I am using the settings they suggested 180c idle and 185c pressing, pressing for 15 seconds. Using Durham Mugs.
Any suggestions will be most welcome. Thank you.
wayupnorth
Post by wayupnorth »
Pressing for 15 seconds ?.
Phil47
Post by Phil47 »
That s what the instructions say
Watch the pressure. Should not be too tight at all. Paper type is important so perhaps look at this as well. As well as that 15 seconds! Should be more like 145-180 seconds.
Phil47
Post by Phil47 »
I have adjusted the pressure, took a bit of getting right! The transfers are fine, but my concern is the tape marks on the mugs.
wayupnorth
Can you post a picture of the marks ?. Where did you get your tape from ?.
Phil47
Post by Phil47 »
wayupnorth;113096 wrote:Can you post a picture of the marks ?. Where did you get your tape from ?.
I have taken an image of the marks, the marks are hardly visible, but they are very visible to the naked eye. Tape from Mega Sublimation Printing Systems.
Quinsfan
Post by Quinsfan »
15 secs??? Still need to know how this works?
Phil47
Post by Phil47 »
Quinsfan;113105 wrote:15 secs??? Still need to know how this works?
That is what MEGA say, what temps and timesdo you use?
Quinsfan
Post by Quinsfan »
180 secs @180 degrees. 15 secs is not even enough time for the ink to turn to gas.
