Sublimation patches white line.
Re: Sublimation patches white line.
I'll start with....I haven't printed any!
Just looking at patches that have already had the edges stitched and thought "Wouldn't there be a white line between the stitching and the main print?"
So assume the patch is white, press it all black, wouldn't there be a white line inside the stitching due to the ridge? I can see the stitching would take the dye, the main body would take the dye, but where it sits a bit proud at the junction of stitching and fabric surely there would be a line.
Just wondering over a cup of coffee ... back to work now.
Janners.
Janners.
Just discovered that the stitching around the outside is called "Edging", never a dull moment.
Janners
Janners
No, it does tend to "fill in".
Thank you. Not that I have any intention of printing any, but my mind does ponder odd things sometimes..this was one of the more sensible moments of pondering.socialgiraffe;111929 wrote:No, it does tend to "fill in".
Janners
- mrs maggot
the merrow edging if it is made of polyester would have a print on as well i suppose, or you would have to be very good at lining up
- Has thanked: 11 times
- Been thanked: 9 times
Any suppliers still selling patches? Quick search didn't throw anything up.
Golden Finishes perhaps? I know Ralawise used to as well.
Just to clarify, I did mean blank sublimation patches
Cheers Simon, will check them out.
Yes mate, pretty sure both those companies still sell them, if you are only after one or two I may have them lying around.
