Epson 1500W
Re: Epson 1500W
Ok, I've had this a few days now and apart from setting up the CIS I've not touched it. I'm now trying to get it up and running but for some reason the disc doesn't auto run and I cant seem to find how to start it manually. Anyone got any ideas on a windows 10 laptop?
Re: Epson 1500W
As far as I know, 1500W is not compatible with W10... The carton of the printer shows Mac, Vista and Seven. Hope it helps
Re: Epson 1500W
Hi Makram. I thought that may be the case. My lappy was windows 7 and I stupidly upgraded to 10. Is there any way back?
Re: Epson 1500W
No idea why my font is so big. My little girls laptop has windows 7 professional so I will commandere tgat for the time being
Re: Epson 1500W
If you upgraded to W10 less than 1 month ago you should be able to downgrade, otherwise you will have to use the Windows 7 disc and restore your computer.
http://www.howtogeek.com/220723/how-to- ... -7-or-8.1/
Re: Epson 1500W
Windows 10 Drivers for 1500w can be downloaded direct from Epson
http://www.epson.co.uk/gb/en/viewcon/co ... port/11350
Re: Epson 1500W
Mugshots;111631 wrote:Hi Makram. I thought that may be the case. My lappy was windows 7 and I stupidly upgraded to 10. Is there any way back?
if you cant revert back...simple ---save stuff you want to keep onto another external HDD or pen.....format the HDD with win 10, and reinstall win 7 pro....reinstall the apps/programs you saved on other external hdd...job done.....simples...squeak !
