Whats happening here
Mugshots
Re: Whats happening here
Post by Mugshots »
On the top of the girls head. Theres a light patch that isnt on the original? Ive printed it off about 4 times now. All the same.
Mugshots
Post by Mugshots »
Apologies. Can this be moved to problems please
Sorry, I have no idea, but have you tried rotating the image?
Either 90 or 180 degrees. If the light patch is in the same place on the girls head it is likely to be a software/computer issue. If the light patch is in the same place in relation to the paper then it is likely to be the paper or the printer.
It could be as simple as a bad batch of paper that has had some substance on it, but that is pure guesswork.
Mugshots
Post by Mugshots »
I did as you said SG and its come out a load better. Thanks
Glad to hear you are sorted, obviously this has not solved the issue but at least it's a workaround
