[Sawgrass SG 400] black dots
malkram
Re: [Sawgrass SG 400] black dots
Post by malkram »
Hello everyone, I recently purchased a Sawgrass SG 400 with Sublijet-HD ink and TruePix paper. Every time I print something, there are very very small black dots, actually it's even smaller than dots (especially in bright colors). Did it happen to you ? Any idea ? Thanks !
malkram
Post by malkram »
Ok I scanned a print I made today. When you look closely (you need to zoom to 100%), there are small black dots on the white/pink.
vB_ID:3855
vB_ID:3855
JMugs
Has thanked: 10 times
Been thanked: 10 times
Post by JMugs »
Press the paper with no image, do you still get the marks? If you do you have a batch of contaminated paper.
malkram
Post by malkram »
Problem is not when pressing, it's when I print, and it's not related to the paper as I tried another one and same issue.
scotty44
Post by scotty44 »
malkram, you mean the square around the picture (looks a little pinky) ?
That's not there on this one....
vB_ID:3859
vB_ID:3859
malkram
Post by malkram »
I'm not talking about the square. In fact the defects can be better seen when you got the print in front of your eyes. Hey I see you have a 3110, it's almost the same as SG 400, could you print my image if I send it to you and send me a pic ? @scotty44
halcyon
Post by halcyon »
I think I'm having the same problem as you malkram. I'm using the same printer, inks and paper as yourself. I've also used two different sg400 and they both printed little speckles on lighter colours. It's not as noticeable when you print it out (but definitely there) but when you heat press it pops out more.
halcyon
Post by halcyon »
Also to add, it's not the paper that's causing the problem. I've tried truepix and xpres paper and both have the same problem.
malkram
Post by malkram »
I will buy an Epson 1500W (european version of Artisan 1430) instead.. I just wasted €420
halcyon
Post by halcyon »
I went through 2 Epson 1500W, they are pretty unreliable. I can't count how many times I suffered head blockages. I'm really impressed by the sg400, it's a workhorse. If only we could correct the speckling issue it would be perfect.
