Oki laser printer toners query
Discuss other print methods.
Ian66
Re: Oki laser printer toners query
Post by Ian66 »
Hi. I have an Oki C531dn laser printer which I currently use for general printing such as leaflet inserts. I will be trying out different transfer papers for t shirt printing when things calm down after Christmas. My question is - I am sure compatible toners will be ok for my normal printing needs but not for t shirts. (At least that's what I have gleaned from posts on this forum) So, can I happily swap toners around, for different purposes, or will this totally confuse the printer so it doesn't know how much toner is left in each cartridge?
ArferMo
Post by ArferMo »
you will have to swap the drums also.
Ian66
Post by Ian66 »
So do you mean that when you use compatible toners you have to change the drums? I wasn't aware of that.
ArferMo
Post by ArferMo »
there is quite a bit of toner in the drum unit
Ian66
Post by Ian66 »
OK. I see what you mean. Easier (but more expensive) to stick with the original toners. Unless anyone has successfully used compatibles for transfers?
R.Prints
Post by R.Prints »
I only use compatible toners in my laser and it prints everything as the much more expensive OEM toners would.
ArferMo
Post by ArferMo »
That's good to know Ray.
