is this possible :) (printing inside mug)
abacus1983
Re: is this possible :) (printing inside mug)
Post by abacus1983 »
i am wondering if anyone has attempted printing to the inside of a mug, i was going to attempt it but dont know if a mug press would generate enough heat to pass through the mug to the inside, i was thinking about attatching a picture to the inside adding a lining using heat transfer sheet and then pressing as normal, any info on this would be greatly appreciated.
best regards
carl
Would need to have been coated on the inside which I doubt many are. Have a quick peek at the top of the forum and you'll see similar posts already discussing this.
