i am wondering if anyone has attempted printing to the inside of a mug, i was going to attempt it but dont know if a mug press would generate enough heat to pass through the mug to the inside, i was thinking about attatching a picture to the inside adding a lining using heat transfer sheet and then pressing as normal, any info on this would be greatly appreciated.
best regards
carl
is this possible :) (printing inside mug)
- abacus1983
Re: is this possible :) (printing inside mug)
Would need to have been coated on the inside which I doubt many are. Have a quick peek at the top of the forum and you'll see similar posts already discussing this.
Users browsing this forum: Amazon [Bot], Bing [Bot] and 1 guest
