Aprons
chris888
Re: Aprons
Post by chris888 »
I am very new to the dye sublimation world so would appreciate some advise from some of you experienced guys. I am wanting to print some aprons and have been told they are 65% polyester, 35% cotton. Would they be suitable to print? They are available in various colours so wondered if you could print white on a red apron? Any advise would be greatly appreciated
Quinsfan
Re: Aprons
Post by Quinsfan »
The colours would be faded as it is not 100% polyester also you cant print white in sublimation. You normally print onto white as the sublimation process means that the ink goes into the material. I am no expert or have ever done this but I believe if you try to print onto a coloured material the colours wont be the same. If you try to print blue on red it would come out purpleish or blue onto yellow would turn greenish.
Re: Aprons
Vinyl looks great on aprons if you have a cutter and the designs allow.
James990
Re: Aprons
Post by James990 »
I have printed onto 65% poly and have had no problems with it fading or looking washed out!
