Recommendations for mug/heat tape
Re: Recommendations for mug/heat tape
We're wanting to buy in a load of heat tape, and wondered if anyone had already done the research to find which supplier works out cheapest for buying in quantity. It seems like it's more expensive than it should be, so wondering if we are suffering a 'sublimation tax' on a standard item, or every industry using it is paying the same price.
I get mine from BMS
£1.50 a roll I think (its one of their constant offers).
5mm brown
I'm paying around £1.50-£2.00 per roll off eBay for 10mm brown. Seem to be sellers who specialise in all different widths so maybe worth contacting them for a better bulk deal.
was looking there today, but couldn't find 10mm for less than £2.50
http://www.ebay.co.uk/sch/techdynamic20 ... 2749.l2654
This was last seller I used but he doesn't have any listed at moment. £2.10ea last purchase.
Away til 8th August ... looking at his completed listings, he was last selling 4 rolls of 10mm for £4.95 all in ... £1.24 each
Andrew
Post by Andrew »
Did post earlier but must have clicked wrong button.
We use masking tape and have done for years now. 75p a roll and lasts longer than heat tape as you can use shorter strips. Also use it for taping up the sides of mugs like Pisque mentions on the oven post. Only certain makes will not leave residue though. Must have tested over 40 makes to find the best option.
My wife used to use masking tape (before we met) and accepted the residue as a necessary evil, so haven't gone back to it since.
If you're feeling generous about the best makes, then I'm all ears! ;-)
Just to add that we only ever use 20mm heat tape (easier to manage and use in tape dispenser) and buy from http://ooznest.co.uk/High%20Temperature ... imide-Tape
Andrew
Post by Andrew »
Pm sent for you
