Corners miss print Samsung galaxy S5 cases
3D Sublimation
Reading-Print
Re: Corners miss print Samsung galaxy S5 cases
Post by Reading-Print »
Hey there,
I am having a bit of a problem with the corners on Samsung cases, The rest of the case comes out fine but the corners are a bit patchy as if the ink is not transferring properly. I am using the St-3042 3D vacuum heat press and I am doing two cases at a time with the heat set at 195c and run it for 9 minutes. Is the timing ok? I have tried cutting the corners but still the same thing happens. Any ideas??
Regards
Damian
Using Ricoh Aficio A4 sublimation printer, Epson 1500w A3 sublimation printer, Xpres heat press, ST3042 3D sublimation machine http://www.readingprint.co.uk
