Ring Binder
Help in finding new products.
kermit
Re: Ring Binder
Post by kermit »
Are there any Sublimation Ring Binders available from any suppliers?
if not can anyone suggest another method for customising about 20/25 ring binders.
Keith
ASO Embroidery
Re: Ring Binder
Post by ASO Embroidery »
Does the Magic touch not do these may be wrong but think they did
Sammy
daviddeer
Re: Ring Binder
Post by daviddeer »
You could try these. Look expensive though.
kermit
Re: Ring Binder
Post by kermit »
Can't seem to find much. Maybe have to get someone to print them for me by a different method.
Thanks for the suggestions
mrs maggot
Re: Ring Binder
Post by mrs maggot »
you could maybe have some sign vinyl printed and then apply it yourself ??
cyprian.costelloe
Re: Ring Binder
Post by cyprian.costelloe »
Company I know in scarborough use to print on then with an eco solvent printer, you can get then flat and the rings then clip in..
Re: Ring Binder
Bumping this post, incase anyone knows of any suppliers of ring binders or folders that can be sublimated - need to do about 10 of them, but each needs to be different
Re: Ring Binder
Depending on the size I could UV print direct to the binder for you.
Digital UV flatbed so each one can be personalised. Happy fo ryou to supply the binders if you want.
