Ring Binder
Re: Ring Binder
Are there any Sublimation Ring Binders available from any suppliers?
if not can anyone suggest another method for customising about 20/25 ring binders.
Keith
Keith
- ASO Embroidery
Re: Ring Binder
You could try these. Look expensive though.
Re: Ring Binder
Can't seem to find much. Maybe have to get someone to print them for me by a different method.
Thanks for the suggestions
- mrs maggot
Re: Ring Binder
you could maybe have some sign vinyl printed and then apply it yourself ??
cyprian.costelloe
Re: Ring Binder
Company I know in scarborough use to print on then with an eco solvent printer, you can get then flat and the rings then clip in..
Re: Ring Binder
Bumping this post, incase anyone knows of any suppliers of ring binders or folders that can be sublimated - need to do about 10 of them, but each needs to be different
Re: Ring Binder
Depending on the size I could UV print direct to the binder for you.
Digital UV flatbed so each one can be personalised. Happy fo ryou to supply the binders if you want.
Users browsing this forum: Baidu [Spider] and 2 guests
