What kind of printing is this???
Discuss other print methods.
Spike1865
Re: What kind of printing is this???
Post by Spike1865 »
Apols again folks for my lack of knowledge but could someone tell me what was used to make this badge? It feels like rubber and has a very thin black line around the edge. Is it vinyl? Its on a mates work top and been washes hundreds of times. Never faded or anything. Material its on is 59% protex ? 39% cotton, 2% carbon fibre. Any info thanks in advance.
Looks like a custom made transfer to me. You could do something similar with vinyl. Laser transfer might work but washability might not be as good. If it's on an overall you'll need something pretty hardy.
A11kns
Post by A11kns »
Looks like screen printing to me with plastisol inks.
ASO Embroidery
Post by ASO Embroidery »
Hi
company I deal with class this as a top grade industrial heavy duty transfer you can also get a digital version if your image is more like a picture. I'm sure other transfer suppliers may call it by another name. but its easily available.
Sammy
Spike1865
Post by Spike1865 »
Nice one guys. The cloths he had on have been through all kinds of stuff and its never cracked or faded. What does it cost to buy these heavy duty transfers or how do I make them :)
Subli flock? :)
ArferMo
Post by ArferMo »
Looks like solvent print using Siser C-Print Easy Transfer to me.
Spike1865
Post by Spike1865 »
Sammy. What do the transfers cost and do I apply with regular press? Also, can they fix to many materials, metal etc?
ASO Embroidery
Hi Spike1865.
Yes you just apply with a normal heat press. The cost comes down to the size of the actual decal you require and also the amount of colours. The only downside is that they normally want a minimum order (a bit like screen printing ) So as an example the design you have shown looks like 4 separate colours although it doesn't look to large. What I normally do is send in the artwork with info required and they then quote you a price and its then up to you if you want to go ahead. They also do a helmet decal which I'm reliably informed will attach to almost anything plastic , metal etc. . If you would like the details drop me a pm and will pass on.
Sammy
