Silhouette Cameo Blade Settings
Bob700
Re: Silhouette Cameo Blade Settings
Post by Bob700 »
Hi
I intend to use MDP hotflex T shirt vinyl can any advise on the best blade setting, I will not be using a carrier sheet
Thanks Bob
scotty44
Post by scotty44 »
Set to vinyl, blade 1 , speed 8 and thickness 9 that works for me without the carrier sheet :cool:
viccar
Post by viccar »
Hi use the tool in studio to give me, and adjust blade to what it says, its always a good starting point, if you are not sure use the test cut.
One thing i find is with heat vinyl it doesnt look like its been cut, until you start to weed it.
I use 8 speed 4 thickness and 2 blade but my blade is nearly 3 years old. so maybe a 1 with a new blade.
vB_ID:3326
vB_ID:3326
Bob700
Post by Bob700 »
Thanks for the info/advice
