Sublimation cartridges
rachael.tufts
Re: Sublimation cartridges
I have the ricoh gx3350n which I am going to use for sublimation printing.
Does anyone know if the cartridges from the other ricoh printers are the same size?
rachael.tufts
May I ask why you're using this printer then? Has it already been used or is it brand new?
rachael.tufts
I have used it with unbranded ink but want to use the correct ink for best results
if it's already been used there will still be a lot of ink in the lines that would have to be flushed through. General advice here is to just buy a new printer/inks package as the printer itself isn't that expensive. I don't know anything about this particular model but as it's not supported it could prove a costly trail and error process. Other similar models have failed so best stick to the supported ones.
rachael.tufts
Didnt think about the flushing through.
I think u may be right in the long run it will be more cost effective to start fresh
Thank you
Thank you
No worries, always worth asking
Remember Premium Membership would give you 10% off a printer package with Listawood or Xpres
