Sublimation cartridges
rachael.tufts
Re: Sublimation cartridges
Post by rachael.tufts »
I have the ricoh gx3350n which I am going to use for sublimation printing.
Does anyone know if the cartridges from the other ricoh printers are the same size?
Has thanked: 13 times
Been thanked: 12 times
Is the 3350 a supported printer?
rachael.tufts
No I dont believe so
May I ask why you're using this printer then? Has it already been used or is it brand new?
rachael.tufts
I have used it with unbranded ink but want to use the correct ink for best results
if it's already been used there will still be a lot of ink in the lines that would have to be flushed through. General advice here is to just buy a new printer/inks package as the printer itself isn't that expensive. I don't know anything about this particular model but as it's not supported it could prove a costly trail and error process. Other similar models have failed so best stick to the supported ones.
rachael.tufts
Didnt think about the flushing through.
I think u may be right in the long run it will be more cost effective to start fresh
Thank you
No worries, always worth asking :-) Remember Premium Membership would give you 10% off a printer package with Listawood or Xpres :-)
