hidehi;50403 wrote:Johnny, is it the settings or the blade or the vinyl you are having problems with? Are you running Studio 2.5.8, because for some reason it changed all the settings, so if its any help, I am still running the old version so I can let you have all the original settings. Also what vinyl are you using? I don't understand why you are having so many problems(
hi.....i,m running 2.5.8 - where can i download the older version you guys are running ?...lot of people seem to be having probs with this newer version.
The newer vinyl samples i got were these - http://www.mdpsupplies.co.uk/cameohotflex.asp
and the first ones i got were these -http://www.printerowners.co.uk/garment- ... n-flex.htm
The newer ones dont cut at all, they score the vinyl but not enough to be able to weed any of it.
The first ones i just cant for the life of me tell which way is shiny and which way is matt....both sides look the same to me :rolleyes:....and i have wasted sheet after sheet trying to sort this.....
At least BMS vinyl cuts to some degree....lot better than the other one, which is nearly nil.
i was also told NOT to put my blade above 3 as its not needed....really?...
and to cut without a cutting mat - no chance....chew chew chew......
I still love this little machine and i hope i can sort it out....open to any advice....
Have contacted cameo to see what they suggest.
