flex aint happening
bigj2552
Re: flex aint happening
Post by bigj2552 »
hidehi;50403 wrote:Johnny, is it the settings or the blade or the vinyl you are having problems with? Are you running Studio 2.5.8, because for some reason it changed all the settings, so if its any help, I am still running the old version so I can let you have all the original settings. Also what vinyl are you using? I don't understand why you are having so many problems :o(
hi.....i,m running 2.5.8 - where can i download the older version you guys are running ?...lot of people seem to be having probs with this newer version.
The newer vinyl samples i got were these - http://www.mdpsupplies.co.uk/cameohotflex.asp
and the first ones i got were these -http://www.printerowners.co.uk/garment- ... n-flex.htm
The newer ones dont cut at all, they score the vinyl but not enough to be able to weed any of it.
The first ones i just cant for the life of me tell which way is shiny and which way is matt....both sides look the same to me :rolleyes:....and i have wasted sheet after sheet trying to sort this.....
At least BMS vinyl cuts to some degree....lot better than the other one, which is nearly nil.
i was also told NOT to put my blade above 3 as its not needed....really?...
and to cut without a cutting mat - no chance....chew chew chew......
I still love this little machine and i hope i can sort it out....open to any advice....
Have contacted cameo to see what they suggest.
hidehi
Post by hidehi »
I don't think you can download the older version as its not available now that 2.5.8 is out, but as I'm still running the older version I can screenshot the default settings for you, but I'm not sure that is going to help.
I use mdp hotflex and have had no problems, and I have cut it with a mat and without a mat. I use blade set at no 2 and I have never set it higher than 3 for anything so far. I can't help but wonder whether you have a defective blade. Have you tried contacting Graphtec and explained the problem? They are very helpful and I know they have sent out replacement blades to those that have had problems. Karine is the person you need to speak to.
bigj2552
Post by bigj2552 »
have uninstalled 2.5.8 and......the cd they gave me with my cameo, i fired it in.
silloutte studio designer edition release 2.0.0d...
is this the "OLD" version people keep talking about ? :biggrin:
and i have contacted cameo support....they are getting back to me.
johnny
bigj2552
Post by bigj2552 »
HEY.....fired in the old cd software they gave with the cameo....
put in the MDP vinyl, after more messing around, i had to UP the settings from there recommended blade 1, up to blade 3,speed 4,thickness 33....AND IT CUTS.....YES RESULT....
or is that just a fluke ?...Hmmmm
off to try another sample....
I'll be back.............hasta la cutter baby:cool:
hidehi
Post by hidehi »
As thats good news, well done! I'm sure its not fluke :o) The previous version is 2.5.0 so you won't have some of the newer features with 2.0.0, but at least you have the old cutting settings. For vinyl you shouldn't need to crank it up to 33 thickness, I find 9 is perfect.
Good move on contacting Graphtec, I'm sure they will be able to help.
bigj2552
Post by bigj2552 »
hidehi;50416 wrote:As thats good news, well done! I'm sure its not fluke :o) The previous version is 2.5.0 so you won't have some of the newer features with 2.0.0, but at least you have the old cutting settings. For vinyl you shouldn't need to crank it up to 33 thickness, I find 9 is perfect.
have tryed it at 9,15,20,25,33.....25 cuts through but i,m having to push and tear to get letters out....
9 just cuts outline....doesnt even penetrate enough to weed at all....33 is perfect...clean cut/easy weed and that was on a small size font......still think the blade is kinda wonky
hidehi
Post by hidehi »
Ah okay, so long as you got it to work! Fun times ahead...
bigj2552
Post by bigj2552 »
just cut BMS vinyl at same settings blade 3 - speed - 4 - thickness - 33....PERFECT CLEAN CUT......
it must be something to do with the NEW 2.5.8 software then ?
cause i couldnt get bugger all to work proper - unistall 2.5.8 and fire on 2.0.0b and all is well :rolleyes:.. well, maybe not the same settings as the rest of you, but at least its cutting PERFECT :biggrin:
and......
ive finally managed to figure out the BMS vinyl.....it now cuts great and applyed onto t-shirt no problems.....:biggrin:
off to dye my hair now.....more grey coming through lol - jeez, that sounds gay...i,m not - trust me lol
hidehi
Post by hidehi »
Amazing what a bit of software can do! No matter about the settings being different, it seems to vary between blades, users and types of medium anyhow
bigj2552
Post by bigj2552 »
hidehi;50421 wrote:Amazing what a bit of software can do! No matter about the settings being different, it seems to vary between blades, users and types of medium anyhow
why are they putting updated software out that is obviously faulty somewhere ????
