Arghhh..Gone green again!
JMugs
Has thanked: 10 times
Been thanked: 10 times
Re: Arghhh..Gone green again!
Post by JMugs »
I have run out, two Init Fills drank about 700ml and I now have the cleanest pipework possible.
So I have re-installed the original epson inks, and done a few test prints using the epson drivers...hmm the plain grey is a very good grey, as opposed to the very green I had before. Another general image is not quite popping almost generally a bit dull. But given the age of these printers some deviation is perhaps expected.
Next stage is to profile for the epson paper with epson inks. Then I can see how it looks from there. Mrs Janners can run some some images through it and I can see if it holds it's colour.
If it does she may end up with it as her printer!
Janners
I would expect that you have essentially re-primed the dampers/heads with the init fills, and the pressure will hold for a while, but will gradually fade off again back to where you were (which is what was happening on ours until we got the dampers replaced)
JMugs
Post by JMugs »
Hi Tim
That was my line of thinking, but I was rather unsure. Running standard ink through it and printing on photo paper is rather cheaper and far less time consuming!
So I shall see what happens.
Janners
JMugs
Post by JMugs »
Ohhh found this....very exciting, I feel my inner geek is emerging.
Janners
Forgot the link.... http://www.americaninkjetsystems.com/ep ... epair.html
Yup, that's a good website to keep bookmarked!
Definitely download the service manual, but don't let it scare you - it looks worse than it is in real life!
