Had mind set then...
JSR
Re: Had mind set then...
Post by JSR »
bigj2552;41141 wrote:i am going to buy a cheap epson s22 for back up anyway, regardless of what main printer i buy.
That was always on the cards !
If you go for a Brother as your main printer, I would thoroughly recommend you look for another Brother that uses the same cartridges for the backup. Then, if one printer fails on you, just swap out the cartridges and you're good to go. The great thing about Brother printers is, unlike the Epsons and the Ricohs, the same cartridges can be used in a whole range of printers - because there are no chips involved. Just match your cartridge to a printer.
Why go through all the learning process of the Brother and "lumber" yourself with an Epson for backup. Best to stick to the same brand (all Brother, all Epson, or all Ricoh) - in that way, what you learn on one will apply to the other.
bigj2552
Post by bigj2552 »
JSR;41150 wrote:If you go for a Brother as your main printer, I would thoroughly recommend you look for another Brother that uses the same cartridges for the backup. Then, if one printer fails on you, just swap out the cartridges and you're good to go. The great thing about Brother printers is, unlike the Epsons and the Ricohs, the same cartridges can be used in a whole range of printers - because there are no chips involved. Just match your cartridge to a printer.
thats fine but...
cheapest A4 brother is about £70 - cheapest A4epson about £29.
plus the refillables carts are about £15 cheaper for the epson as well
both would be utilising the same inks anyway....
make my mind up time lol
have to buy this week regardless...times a running out ..i gave myself a date for starting/opening and im sticking to it :-)
but you must think about profiles too :) i stand with JSR on this one! stick to one brand.
JSR;41135 wrote: One of the things we don't yet know about Brother printers is what happens when the waste tank gets full (or even if it has one!). Ricohs apparently have a replaceable waste tray. The Epsons can be reset with a utility. But what of the Brother? I would recommend a two-printer set up. By all means have a 5890CN for A3 work but it may also be wise to seek out a cheap A4 model for day-to-day work. If the ink tank becomes an issue, the A4 can be dumped without wasting the more expensive A3. After all, at £20, my MFC-295CN was less than the cost of the waste tray for a Ricoh!
There is waste ink bag in dcp models. And I just reset my printer waste counter :wink:
JSR
Post by JSR »
Paul;41328 wrote:There is waste ink bag in dcp models. And I just reset my printer waste counter :wink:
Can you provide further details? Photos of how to get to the waste bag, and what you use to reset the waste counter?
I actually in the process of opening this. i reset my printer only at this moment. Used key combination to reset it :).
JSR
Post by JSR »
Paul;41334 wrote:I actually in the process of opening this. i reset my printer only at this moment.
I'm interested in this, as you can imagine. How did you find out where the waste bag is?
i read a lot and i know there is plenty people that managed to open this printer and empty the bag. i am going to do this asap ;)
bigj2552
Post by bigj2552 »
Paul;41345 wrote:i read a lot and i know there is plenty people that managed to open this printer and empty the bag. i am going to do this asap ;)
also very interested m8 :wink:
i am going to open my and take some pictures for step by step :D
Users browsing this forum: No registered users and 14 guests
