Had mind set then...
bigj2552
Re: Had mind set then...
Post by bigj2552 »
had set my mind on the epson b1100 printer but then,
i was reading through JSR post i think....liked the brother MFC-5890CN A3 printer...all in one printer(scanner ect) and you can use ciss refillable cartridges with it...lot easier to get into and fill than the epsons...
and this printer seems to have a better track record than the epsons for some reason !
thats that then..FINALLY..no more looking - this is it ....buying it this week coming so i cant change my bloody mind...again ! :tongue:
luv this forum but sometimes...lol...just when you think you are ready to buy something then....you find more info on something else :wink:
great forum with invaluable info
johnny...
heheh... just wait when troubles start :)
Paul;41120 wrote:heheh... just wait when troubles start :)
That's a serious point really. Support for the Brother printer will be restricted as so few people use them.
John G
Post by John G »
There is at least one forum member using a brother for subbing that may be able to steer you in the right direction.
You will need a profile made to use this printer.
bigj2552
Post by bigj2552 »
John G;41129 wrote:There is at least one forum member using a brother for subbing that may be able to steer you in the right direction.
pauls the man for that one m8 :-)
bigj2552
Post by bigj2552 »
why is buying gear for this business so dam awkward....jeez my other business, you buy the vehicles, get the contracts, do the work...simples !
sublimation...wow....other end of the ballpark.....suppose it depends on how picky you want to become with this ?
JSR
Post by JSR »
bigj2552;41119 wrote:had set my mind on the epson b1100 printer but then,
i was reading through jrs post i think....liked the brother MFC-5890CN A3 printer...all in one printer(scanner ect) and you can use ciss refillable cartridges with it...lot easier to get into and fill than the epsons...
johnny...
[h=1][/h][h=1][/h]
I'm using two Brother printers at present (the DCP-195C, and an MFC-295CN). I don't use my MFC-5890CN for dye-sub yet, but I will do when it becomes necessary. I also have four Epson printers here (B40W, 2x1400, and a 1290S) not counting my R1800 (not used with dye-sub). I have a choice what to use, and I primarily choose the Brothers.
Whenever you go down the unsupported route, you take the responsibility upon yourself to sort out your own problems as you go along. I'm content with doing that, albeit I felt kind of forced into it because of the severely limited options available from the "supported" options. It seems bizarre to me that we pay Sawgrass great wodges of cash for their ink, and in return we can only use the couple of printers they allow us to use. But that's the way of things, I guess, when the tail wags the dog.
No one can say whether the Brother printers have a "better track record" than either Epson or Ricoh when it comes to dye-sub ink because so few people use them for this purpose.
Historically, Epson have a "poor track record" because so many people complain about them. However, Epson is the most prolific of desktop dye-sublimation solutions. If 1,000 people are using them and 100 people complain, then it feels like everyone's complaining about them when only 10% are having problems and 90% are doing just fine.
Ricoh appear to have a better track record, but more and more posts are appearing on this forum of people having difficulties - with colours, and whatever else. This is because the Ricoh printers are becoming more popular. They're being pushed by suppliers and Sawgrass as the "easy solution" based, presumably, on the lack of complaints so far. After all, if only 100 people are using them and 20 people complain, then you won't see many problems. The number of complaints appears to be a lot less (using these arbitrary figures - 20 for Ricoh, 100 for Epson), but the percentage shows the Ricoh being the worse printer (20% complaints, compared to 10% for the Epson) - all figures for illustrative purposes and not intended to imply fact.
It's a question of scale. The more a printer becomes popular, the more people will have problems, and the more complaints you'll see. Conversely, the less popular a printer is, the less people will have problems, and the fewer complaints you'll see. It doesn't necessarily mean either printer is any more vulnerable or invulnerable than the other.
My only advice is to choose the printer setup/system that ticks the most boxes for you. By all means be guided by the complaints of others, but consider how many people are *not* complaining about that particular printer. I chose Brother for my own reasons (I wanted to get away from using a CISS, and I didn't feel that Sawgrass were offering enough alternative options). I accepted putting in the time and effort required to see if Brother printers would do the job, and I continue to accept that there's very few people who I can discuss this particular set-up with.
If you do run into problems with your Brother set-up, then there will be very few people who can help you - so you won't be able to put a "help!" post on the forum and expect an instant reply, or a reply at all. You're on your own.
One of the advantages of Brother printers to me is that you can get them fairly cheap (my recent MFC-295CN cost me about £20) so, if something insurmountable happens, it goes in the tip and I buy a new one. That's not so easy to do when you spend £100+ for an A4 printer or £300+ for an A3 one. The more you spend, the more you *have* to sort out problems. The less you spend, the more inviting the tip looks. :wink:
One of the things we don't yet know about Brother printers is what happens when the waste tank gets full (or even if it has one!). Ricohs apparently have a replaceable waste tray. The Epsons can be reset with a utility. But what of the Brother? I would recommend a two-printer set up. By all means have a 5890CN for A3 work but it may also be wise to seek out a cheap A4 model for day-to-day work. If the ink tank becomes an issue, the A4 can be dumped without wasting the more expensive A3. After all, at £20, my MFC-295CN was less than the cost of the waste tray for a Ricoh!
2 of them :cool:
bigj2552
Post by bigj2552 »
@JSR - "After all, at £20, my MFC-295CN".....where you getting it for £20 ?..cause i cant find that printer available at all anywhere ! - second hand on fleabay ?
i am going to buy a cheap epson s22 for back up anyway, regardless of what main printer i buy.
That was always on the cards !
JSR
Post by JSR »
bigj2552;41141 wrote:@JSR - "After all, at £20, my MFC-295CN".....where you getting it for £20 ?..cause i cant find that printer available at all anywhere ! - second hand on fleabay ?
Yes, that's where I bought that one from. New Brother printers start at around £50 (DCP-195C). Before Christmas, I wanted a second one for backup so I scoured eBay looking for suitable models that would cost £20-£30, and then bid on them if they sounded okay. Most of them were sniped by other ebayers but, after a couple of weeks of trying, I finally got the 295CN for about £22. Postage was about a tenner more, but the printer turned out to be as good as new almost. Just took out the installed cartridges, flushed through some cleaning fluid to get rid of the ink in the lines, then put the dye-sub ink in and got it profiled.
It's actually working a little better than my original DCP-195C, and it's networkable too. All in all, a fine addition and a snip at the price. (Even the scanner has an ADF.)
