Problem with fading areas on ceramic coaster
Jessie
Re: Problem with fading areas on ceramic coaster
Post by Jessie »
Hi, I've just started printing onto ceramic coasters and have noticed a little fading on some areas after pressing.
I've read on here about using a heat conductive rubber pad helping to even out the surface but am not sure where I can buy this from and if I need a certain thickness?
Thanks in advance
J
Post by GoonerGary »
Check that you have the correct pressure set on your press. Run your finger over the coaster and see if it is bumpy where there is fading.
http://www.ebay.co.uk/itm/Silicone-Extr ... 4627e97c77
Jessie
Post by Jessie »
Thanks for the advise and link GoonerGary. I will check the pressure setting.
The fading is in a small area on the coaster (about 8mm in diameter) and although the coaster feels smooth I think it's a little uneven so the silicone layer should help.
If it fading where it is bumpy, just put it down to a bad coaster and don't make any adjustments, although increasing the pressure might help.
Jessie
Post by Jessie »
I tried with another coaster and it came out great but then the next one has a small patch of fading like the first one? I added the silicone layer and more pressure and they are now all turning out fine - thanks for your help :-)
