bit impressed with myself !!!!!
Mumfy
Re: bit impressed with myself !!!!!
Post by Mumfy »
Morning, I am a self confessed giver uppera !!! (yes that's a word I invented it !!) anyways , we got this heat press , easy 4 months ago , bought a load of blanks etc, wasted a load of blanks etc.... so turned it off- stuck 2 fingers up to it and left it .
well, at the weekend we looked into Max spielbergs window and saw a heat press, so said to the guy - do you use that he said yeah - so i just said i cant use mine and he told me that they have a list of times and temps , so.... lets just say he was errrr, errr, helpful ! , told me one setting for a mouse mat...
So this morning i turned the pain in the butt back on set the temp at 300 ,med pressure, and 60 secs.... and guess what OMG - it only went and worked !!!
I was a bit scared that i would start a fire and melt the mat - but it did stick to the plate , but before i could get something to get it off - it fell off !.
took the pics of and im like ''Gangnam style'' !!!
I have posted a pic below (not a good un) taken on fone
- all the other feint pictures are me trying all other temps and times (fed up with wasting stuff).
So at least now i know it works --- wonder if i go back and get some more times from Mr Max LOL
vB_ID:3259
vB_ID:3259
vB_ID:3259
vB_ID:3259
vB_ID:3258
vB_ID:3258
mrs maggot
Post by mrs maggot »
time and temps are available on most suppliers websites, there is even a poster you can download on xpress website, as with most things its a case of trial and error for your particular set up
James990
Post by James990 »
If you had your actual location instead of just United Kingdom, you might have found some-one near you who might be able to help!
James
Mumfy
Post by Mumfy »
mrs maggot;96732 wrote:time and temps are available on most suppliers websites, there is even a poster you can download on xpress website, as with most things its a case of trial and error for your particular set up
i got my blanks from longforte - and did see the temps and times , but they didnt work for me , I will have a looka t xpress one tho , thanks
Mumfy
Post by Mumfy »
James990;96735 wrote:If you had your actual location instead of just United Kingdom, you might have found some-one near you who might be able to help!
James
have sorted that out now James , Thanks for the advice. some people wont give you info - as they may see it as I'm stealing their customers
ArferMo
Post by ArferMo »
Mumfy;96739 wrote:..... some people wont give you info - as they may see it as I'm stealing their customers.....
Ummm true, unfortunately I have found that syndrome on here too..... MUCH to my surprise :confused:
James990
Post by James990 »
Well they must be very insure then in what they do, is all I can say. We are on the whole, a very helpful bunch, agreed we wont give away any of our trade secrets, but helping one and another out is what we do. If you read through some of the treads, you will see offers of, 'you are close by, pop in and I will show you how to do so and so' or 'I'm just down th eroad from you, I'll pop in and see how I can help', etc.
James
Renniwano
Post by Renniwano »
I would agree with Mrs Maggot on this one.. it is a little trial and error but every supplier gives you at least a starting point.
Once you have them.. write them down and then you will end up with your own list of times, temps, platen pressures.
We all have different machines, inks, blanks etc.. so nothing will ever be exact but near enough.. and welcome back to the world of sublimation :)
Mumfy;96738 wrote:i got my blanks from longforte - and did see the temps and times , but they didnt work for me , I will have a looka t xpress one tho , thanks
Question to ask is your press temperature scale? is it in centigrade or Fahrenheit? If you had to set your press to 300 then i doubt is in "C". so most of times and temps from supplier websites won't work as they are in centigrade.
James990
Post by James990 »
Mumfy,
A very good example about helping each other is going on right now with me and Paul, a Super Moderator on this forum. I bought some templates from his site, and somehow the time for downloading them run out, he has gone into the site and reset everthing for me, so I can get them, also a while back I crashed the hard drive and lost everything on it, again Paul came to the rescue. Now he didn't need to do that, he could have said tough, but he didn't.
James
