A real newbie question, sorry !!!
Re: A real newbie question, sorry !!!
OK, I am contemplating getting into mug printing, I currently run a PC & Laptop repair business but need to generate some more cash, certainly until I am more well known !!!
I know I have to get a printer that can print the transfer paper & I know I need a Mug Press, along with a few other bits & bobs, but my question is regarding the printer. Can I use it as a "normal" printer as well, or should I use it only for the transfers and keep my current printer for general printing ? If I can use it for both jobs, is that going to be a particularly expensive way of running a printer (are the inks for sublimination printers more expensive than "normal" printer ?) ?
Thanks in advance ...
- mrs maggot
make yourself a cup of coffee, and have a good read of the forum, all of your questions will be answered by having a read - welcome
I am reading the Forum, mrs maggot, but I was hoping that I might find out within hours rather than days, possibly weeksmrs maggot;94077 wrote:make yourself a cup of coffee, and have a good read of the forum, all of your questions will be answered by having a read - welcome
Very short answer....
Sublimation printer needs sublimation ink. Look at something like the Ricoh A4, carts for sublimation are about £40.00 each so would be very very expensive to run as a normal printer.
Get a good SUBLIMATION printer (Epson or Ricoh), a recognised manufacturer of MUG PRESS and purchase Sublimation mugs from a REPUTABLE Supplier and you will be fine.
Good luck
Good luck
Perfect answer, thank you, I will go researching and comparing :biggrin: ...socialgiraffe;94089 wrote:Very short answer....
Good luck
buy original, use original ,dont think you will save money by buying china ink and china paper, use the proper printer and paper and ink before you even start.£500 will set you up.
Directdesignsupplied.co.uk
Thank youAngloman;94091 wrote:buy original, use original ,dont think you will save money by buying china ink and china paper, use the proper printer and paper and ink before you even start.£500 will set you up.
I did at first and don't due it, I went to listawood and bought a new printer proper ink and proper paper, have not looked back
Sorry, 1st post I know, I will introduce myself separate. I can't agree with this enough, I'm over £300 into a printer which is useless all because I tried to do it on the cheap. I ended up spending another £225ish on a brand new Ricoh because I'd had enough. Buy genuine always.Angloman;94091 wrote:buy original, use original ,dont think you will save money by buying china ink and china paper, use the proper printer and paper and ink before you even start.£500 will set you up.
