A real newbie question, sorry !!!
StellaMan
Re: A real newbie question, sorry !!!
Post by StellaMan »
OK, I am contemplating getting into mug printing, I currently run a PC & Laptop repair business but need to generate some more cash, certainly until I am more well known !!!
I know I have to get a printer that can print the transfer paper & I know I need a Mug Press, along with a few other bits & bobs, but my question is regarding the printer. Can I use it as a "normal" printer as well, or should I use it only for the transfers and keep my current printer for general printing ? If I can use it for both jobs, is that going to be a particularly expensive way of running a printer (are the inks for sublimination printers more expensive than "normal" printer ?) ?
Thanks in advance ...
mrs maggot
Post by mrs maggot »
make yourself a cup of coffee, and have a good read of the forum, all of your questions will be answered by having a read - welcome
StellaMan
Post by StellaMan »
mrs maggot;94077 wrote:make yourself a cup of coffee, and have a good read of the forum, all of your questions will be answered by having a read - welcome
I am reading the Forum, mrs maggot, but I was hoping that I might find out within hours rather than days, possibly weeks :smile:, there are thousands of messages on here ...
Very short answer....
Sublimation printer needs sublimation ink. Look at something like the Ricoh A4, carts for sublimation are about £40.00 each so would be very very expensive to run as a normal printer.
Get a good SUBLIMATION printer (Epson or Ricoh), a recognised manufacturer of MUG PRESS and purchase Sublimation mugs from a REPUTABLE Supplier and you will be fine.
Good luck :-)
StellaMan
Post by StellaMan »
socialgiraffe;94089 wrote:Very short answer....
Good luck :-)
Perfect answer, thank you, I will go researching and comparing :biggrin: ...
Angloman
Post by Angloman »
buy original, use original ,dont think you will save money by buying china ink and china paper, use the proper printer and paper and ink before you even start.£500 will set you up.
Directdesignsupplied.co.uk
StellaMan
Post by StellaMan »
Angloman;94091 wrote:buy original, use original ,dont think you will save money by buying china ink and china paper, use the proper printer and paper and ink before you even start.£500 will set you up.
Thank you :smile:
Angloman
Post by Angloman »
I did at first and don't due it, I went to listawood and bought a new printer proper ink and proper paper, have not looked back
howarth
Post by howarth »
Sorry, 1st post I know, I will introduce myself separate. I can't agree with this enough, I'm over £300 into a printer which is useless all because I tried to do it on the cheap. I ended up spending another £225ish on a brand new Ricoh because I'd had enough. Buy genuine always.
Users browsing this forum: Google [Bot], Semrush [Bot] and 1 guest
