Liyu SC631E cutter plotter optical eye.
Re: Liyu SC631E cutter plotter optical eye.
So i am new to all this malarky and having nothing but trouble! Bought this machine from signzworld but it seems to be broken! Plugged it in and the motor holding the cutter was off the rail, so sure it wouldnt work. Fastened it onto the top runner and the bottom runner and now its aligned all the way right and sounds horrid!! Like its going to combust! Have i just put it back on the runner wrong? Help!!! please lol x
Unafraid to ask for help!:rolleyes:
demo of what this cutter is doing and i dont know how to stop it/ fix it.
PrinTnTech
I got one of these stashed away, i will dig it out and have a look at what its setup does as it could be that the belt is in wrong place. have you not tried emailing signzworld about, actually thats where i bought mine and found it quite a good machine.
I have fixed it, the bracket at the back wasnt connecting to the cut off leaver to tell the machine to stop trying to go further right... * woman, dont expect tecnical terms*. So!!! one issue solved * well 2! spent too long trying to find the drivers to get it going as well* now i cant get it to recognise i am sending a job thus still nothing but a test square cut :'(.
Thanx for the suggestion PrinTinTech!
Anyone with this machine have time to go threw it with me? Via pm if you wish? or a phone call? I would be ever so grateful.
A picture is worth a 1000 words?
Hope this will help anyone who has the same issue.
[ATTACH=CONFIG]2942[/ATTACH]
- vB_ID:2942
- IMG00970-20140823-1359.jpg (111 KiB) Viewed 1 time
- vB_ID:2941
- IMG00969-20140823-0922.jpg (94.63 KiB) Viewed 1 time
soulclaimed
Signzworld must be bad for issues as when I got my first liyu cutter the belt that drives the cutter was hanging loose then the second one they sent was fine for a few days and after a week or so of off and on use the power button. Wouldn't turn off so when I finish using it I have to turn it off at the wall should really have sent it back I've had it about a year and a half Noe and its still working fingers crossed
I must say i love this machine, and i do think you get what you pay for....If you need top notch get a roland and a bank loan lmao
