One of the hardest parts of making canvas is getting the corners folded correctly. There are several ways to do this but I am happy with this one. Incidently the technique video was originally published on You Tube so not my idea. However I think this set of stills is easier to follow and have added cut lines and other detail so that may help.
PDF is here: PDF
Folding canvas corners
wayupnorth
- WePrintForYou
Re: Folding canvas corners
Good guide, you can get the exact same result with no need to cut though
The stapler you use is key though
Large Format, Sublimation, Direct To Garment Wholesale Manufacturer. No Minimums
wayupnorth
I guess the idea is to remove as much canvas as possible to make folding easier. Never really looked closely as to why particular cuts were made, it just seems to work for me
- WePrintForYou
That is the reason, but it takes unnecessary time to achieve this.
We product about 50-100 canvas a day at the moment and don't have any issues.
wayupnorth
100 a day - I wish !!. Probably average 2 a week so plenty of time. You will also be using a machine so no cutting necessary I presume.
- WePrintForYou
We make them still by hand, just trim using a template then cut the excess off once stapled on the backwayupnorth;91034 wrote:100 a day - I wish !!. Probably average 2 a week so plenty of time. You will also be using a machine so no cutting necessary I presume.
