HELP! Please... problem with printing shadows
SilentAlf
Re: HELP! Please... problem with printing shadows
Post by SilentAlf »
Hi All,
As you can see in the attached photo black lines are appearing in the shadowed area when only. Does anyone know how I can fix this?
My printer is a Ricoh SG3110DN Printer and I use Photoshop elements 6.0
Many thanks,
vB_ID:2811
vB_ID:2811
Have you printed a nozzle test pattern to check your inks are all flowing 100%
SilentAlf
Post by SilentAlf »
Hi Pisquee, yes I completed a nozzle check after and printer it again and it still printer with the lines. Thank you for your reply
JMugs
Has thanked: 10 times
Been thanked: 10 times
Post by JMugs »
Next suggestion is an alignment check. I assume you mean the arching lines at the top where there is (or should be) a smooth gradient. I don't see why that would cause the issue there alone, but....
Janners
Quinsfan
Post by Quinsfan »
I only use Corel but before I print I use the wireframe view to check that I have no hidden lines. Are the lines on the paper before printing.
SilentAlf
Post by SilentAlf »
Thank you for the replies, I have done the alignments and the lines are still showing :frown:
JMugs
Post by JMugs »
What happens if you convert the image to bitmap? I say this because I was sent an image that just printed with colours all to pot. It was a bitmap pattern that in it's self should not have been a problem, convert to straight bitmap...problem gone. I don't understand it but it worked!
Janners
SilentAlf
Post by SilentAlf »
Hi JMugs, I have converted it to bitmap but it went I had a message say that it had to be converted to grayscale first so I clicked OK then its all gone black any white lol
JMugs
Post by JMugs »
How odd, there is an option to go grey scale..but you should have the option to go full colour.
Send me the image and Ill print one off to see what happens. I'll PM you.
Janners
JMugs
Post by JMugs »
The image here is printed out by me through photoshop and coreldraw with no lines...anybody able to shed more light on this using a ricoh 3110
[ATTACH=CONFIG]2812[/ATTACH]
vB_ID:2812
vB_ID:2812
