switching over from oven to press
Re: switching over from oven to press
I would say to preheat the bases - there's a lot of ceramic there that sucks the heat away from where you're wanting it.
And tighten up your press to compensate for the non-straightness of your mugs.
Frostee
Post by Frostee »
Maybe try putting a heat mat around it inside the press. Can't remember the proper name. They're used on things with potentially uneven surfaces like rock slates
Graphtec CE6000-60, Sefa Rotex Pro Auto Open Swing, Galaxy Mug Press Pro, Epson P800 with sublimation inks, Ryonet Screen print setup
Renniwano
Post by Renniwano »
I use Listawood mugs, Listawood Genie press.. and when doing a full wrap image, heat the base of my mugs on a teppanyaki grill.. only ever issues I have are with the odd mugs that had a slight taper at the bottom.. might be worth looking at what mugs you are using and heating the bottoms if you are going to the bottom..
bycandlelight27
Post by bycandlelight27 »
Thank you all for the advice, I'll start with heating the bottom of the mugs as hopefully this will help,
I used the same mugs when I was using the over an didn't have this issue so it makes sense that that will fix the problem.
The mugs have a diffrent colour inside and can be bought at quite a few different supplies including Coralgraph
Thanks so much
Glen Print
Post by Glen Print »
Hi there. I have had a mug press (for mugs, naturally) and a heat press for slates and the blank style phone covers. Our website will be launched in the next two weeks and we are advertising the wrap-around style covers as well. We were looking towards a vacuum press which will do 12 mugs at one go. Apparently this machine will do all the phone covers and slates too. There is a company in the midlands which sells them for around £700. Would this be value for money as the gentleman who started this post has moved away from the oven? Help and advice needed.. please.
