Does anybody know where to get the plastic for above shop fronts? (already cut to size) for shop signage? I'm only planning to put normal sign writing (vinyl) on the plastic. thanks
Plastic for shop signs?
edwardsmedia
Re: Plastic for shop signs?
Hello,
If you search in google for foamex you should be able to find a few suppliers, unless it is going to be mounted on a solid board it would be best to go for 5mm over 3mm
Foamex is not for shop signage. It has a foam core and is not durable enough for the outside world.
You need an acrylic panel sometimes called perspex. This comes in all sorts of colours. Is it to go in an existing frame? Is it illuminated? You can always use Di Bond panels if you just want a long lasting panel with which to apply the vinyl to.
Alot of printers use it for external signage, our shop sign is printed 5mm Foamex and still looks as good today as the day it was put up however you've got me worried now
[ATTACH=CONFIG]2717[/ATTACH]
- vB_ID:2717
- shop14.jpg (93.21 KiB) Viewed 17 times
Aluminium composite panel or hoarding panel (skybond/dibond/ebond). Cheap ali faced composite board ideal for signage.
Lasts for ever, doesn't go brittle like foamex after a few years, and it can be cut with a sharp Stanley knife.
I wouldn't used foamex for shop signage either - unless it was temporary.
Cheers John
Cheers John
edwardsmedia
Thanks for all your help! Slowly getting somewhere...
I had a google and found this company which some of you might find interesting also, Seems good prices? Although i'm not 100% sure as i have never bought signs... yet
This company sells the dibond stuff and just plastic acrylic sheets etc? which might work?
http://www.cutplasticsheeting.co.uk/dib ... ite-sheet/ - Dibond
http://www.cutplasticsheeting.co.uk/col ... rylic.html - Acrylic in lots of sizes including custom sizes
http://www.cutplasticsheeting.co.uk/signage-materials/ - Sign info
Prices seem steep - try Amari, Pyramid display or Rob Hornes.
Buy the largest sized sheet you can afford (think its around 2440 x 1200) and ask them to cut it to the size you require. That way you'll have off cuts for your next job. White is the cheapest and the value brands such as ebond or hoarding panel are ideal.
Cheers John
Cheers John
Hi TJAlot of printers use it for external signage, our shop sign is printed 5mm Foamex and still looks as good today as the day it was put up however you've got me worried now
Don't panic
edwardsmedia
Sweet!
Thanks for the help all including you John.G! I shall take a look at them now
