Chromaluxe Panels
Re: Chromaluxe Panels
Hi guys
Can you get Chromaluxe panels 50 inches wide?
I have a customer that requires either of the following:
30x30 inches 5 off or 47x33 inches 5 off
If anyone would like to give me a price then please feel free to PM me. Please note that the images are iconic images and I will be checking your websites to ensure that you currently do not infringe copyright as I can not take the risk of these entering into the public domain :biggrin:
largest size available from XPres is 1 metre x 70 cm which seems the best fit available for the size you're wanting (this only available in gloss white)
(which is about 40x30in in inches)
around £50 plus VAT per sheet, so not cheap though.
You'll need someone with a big enough flat bed press too to be able to print it
I looked at a press for these, then spotted the 3 phase power supply needed.
Janners.
Janners.
I've spotted a few older presses from time to time on Ebay that would be suitable for this size, but were only single phase - would have had one if we weren't outbid!
I did see one but it was £5000 used! It was also going to be a bit of a challenge for my Solar Panels, it was a 5 KW draw!
Janners
Janners
- Alastair@Xpres
Hey SocialGiraffe, if you want bespoke sizes of panel you can get these made up for you. We can offer them here at Xpres but I would have to ask as to the bulk you would need to order to get bespoke sizes made. We have a big range here however but I do appreciate that bigger is better.
Could I ask what press you would be using? If you need any advice on pressing the larger panels let me know, I specialize in sublimation and we came up with some comprehensive instructions on achieving high quality, supersize Chromaluxe panels. There is a real knack to it as we found out the hard way!
[CENTER]Xpres Sublimation [/CENTER]
[CENTER]Powering Personalisation
http://www.xpres.co.uk/c-41-sublimation-xpres.aspx?
Email me on alastair.palethorpe@xpres.co.uk for equipment advice or quotes
Might be good to have a guide to these in the Xpres section at some point Alistair? I noticed on your site today that you advice using a particular material to press with. i've had good results with the A3 size I work with but it's a pain if you do mess them up as they're not cheap. Anything you can do to help avoid this would always be useful
Conde also have some good video guides on large format Chromaluxe printing on YouTube
If it is the one where they pre-press the panel it is good. It's the way I do it....but learned the hard way!
Janners.
Janners.
