Just how are you pressing the CPM paper?
Toner on to metal needs a slow bake. You need an A-Pad (5mm thick silicone rubber pad) then place metal on the press, CPM facing it and the pad over the top. press 160/165 for 2 minuites at a medium to high pressure.
Remove from press, allow to cool and then peel the CPM off. Video here
http://www.themagictouch.tv/cpmtrophy.html
To gloss and harden the result place the peeled metal toner side up under the press and "grill" the finished plate for 3-4 minuites, this will melt the surface giving a bit of a gloss and harden it.
For the brave a blowtorch can be waved over the result to do the same but care is needed to prevent burning!
The images look like the toner boiled
Clean toner off with acetone, you may get slight shadow left but usually overprintable
alan
