Metal plaques
Discuss other print methods.
A11kns
Re: Metal plaques
Post by A11kns »
Is it possible to print on to a metal plaque and still keep the background 'metal'? I want to sub black and red text on to a Aluminmum plaque.
Re: Metal plaques
if you don't apply background colour then yes :rolleyes:
A11kns
Re: Metal plaques
Post by A11kns »
what kinda coating is on the metal to allow the ink to take? - I want bright colours like you get on a mug but on the metal
Re: Metal plaques
Base of every colour i white. So if you sublimate on white aluminium you will get bright and vivid colours. If on metalic colours you will be limited. But you should try and sew. Metal prints lovely.
btw... Coating is clear.
Re: Metal plaques
The only way you will get "bright" colours on say a silver metal is by using an OKI white which will back the colours with white. Otherwise anything you print on the metal will obviously be affected by the base colour (in this instance grey/silver).
Alternatively you can print on to a white coated metal but that might defeat the object of what you are trying to achieve.
SUBLIMETALS do an excellent range of metals for pretty much anything
Andrew
Re: Metal plaques
Post by Andrew »
Colours will be bright on silver but they will have the metallic effect with the grain showing through. You need to remember the inks are opaque so whatever the background is it will show through.
A11kns
Re: Metal plaques
Post by A11kns »
Thanks for the advice gents. I thought it was linkly I would need a base of white. I think what I want to do wouldn't be possible.
The plaques I wanted to make are to be replacements for the plaques owners have on their cars in my club.
Below ow is a photo of what I wanted to achivr.. But now think its a none starter.
Re: Metal plaques
I do not see that as being that difficult?
Only thing i would do is use an OKI White or find someone who has one...
Dave271069
Re: Metal plaques
Post by Dave271069 »
socialgiraffe;77173 wrote:I do not see that as being that difficult?
do you know anyone simon that has a oki white ;-)
A11kns
Re: Metal plaques
Post by A11kns »
Oki white? What is this? (Off to google)
