Ricoh SG 3110 Faded Black Problems
porkchop34
Re: Ricoh SG 3110 Faded Black Problems
Post by porkchop34 »
Hi everyone,
I am a sublimation noob and I have set up a small business doing iphone covers through sublimation.
My issue at present is faded black images.
Every other colour comes out perfectly using my setup.
I have tried numerous times to print with numerous settings 170 -190 degrees with 60 up to 120 seconds but no avail, the other colours look great while the black is very matty and faded.
I am using Photoshop Cs6 with Powerdriver, I followed the Sawgrass guide to a tee in setting up the printer etc. I am using truepix setting for paper and perceputal in cs6 setting and saturation in powerdriver setting.
I am using paper from Coralgraph and a coralgraph Heatpress also.
The print outs seem to be much darker than what ends up on the sheet but at the same time leaving it for longer time/ more pressure/ extra temp doesnt change the outcome.
I also have taken the plastic off :)
I will try upload a few photos to the post now.
Regards
Adam
vB_ID:1917
vB_ID:1917
vB_ID:1916
vB_ID:1916
Coralgraph have some great products, unfortunately their cheap paper isn't (in my experience) any good :-( This may not be the only problem here but a good starting point would be to get some Trupix paper and have a go with that....you'll see a big difference.
Sawgrass
Post by Sawgrass »
Please will you send this same message to our Tech Dept at [EMAIL="support@sawgrasseurope.com]support@sawgrasseurope.com[/EMAIL], as they may be able to tweak your setting to improve the black, or tell how else to improve the print. It may also be a paper issue, with not enough ink being released.
thanks
to me look like printed on wrong side of paper as it look grainy as hell :)
porkchop34
Hi guys thanks for the quick reply,
I am a poor Uni student who is trying to make some money out of this so hence the cheap paper.
What paper would u recommend and what source?
Paul, I have been printing on the shiny side but this paper's shiny side isnt all that shiny :/.
Ill try the "matty" side now to be sure (I tried and its much worse on the black see pic below) , ill attach some non black ones and they look really good but anything with black is fairly pants.
I am using white metal as my substrate type I assume that is correct yes?
Regards
Adam
vB_ID:1921
vB_ID:1921
vB_ID:1920
vB_ID:1920
vB_ID:1919
vB_ID:1919
vB_ID:1918
vB_ID:1918
i would always recommend texprint HR very good paper for all substrates. but truepix is good too. also xpres does economy paper that is great.
Agree with Paul there, Xpres paper if you're on a budget.
You haven't told us what printer and inks you're using?
porkchop34
Hey Justin,
[h=2]I am using a Ricoh SG 3110DN as in the title, I am using the sawgrass ink for this printer I believe.[/h]
Is there any settings or mistakes I am making or is it more a paper issue?
Sorry, ignore my stupidity!
porkchop34
No worries Justin mate :)
Should i try a different program other than Photoshop maybe?
