Dye Sub Clock
HeartlandsElliot
Re: Dye Sub Clock
Post by HeartlandsElliot »
Hi All, I have been using (with great success) the dye sub clocks from xpres. However one of my clients has requested a bigger version. I am looking for one around 12" x 9" as the xpres clock is quite small (around 8 x 5.5"). Can anyone suggest a supplier in the UK for me to try? Thanks in advance Elliot
Re: Dye Sub Clock
BMS do a glass clock that is 11.5" diameter. Failing that they also sell just the mechanism so you could source your own base plate to any size you require.
NASH
Re: Dye Sub Clock
Post by NASH »
i use a 12x10 placement and drill my own hole in the middle and buy the mechanism seperately from BMS
Re: Dye Sub Clock
Mechanisms I get off eBay, way cheaper. Last ones I did were metal but I avoid doing them now as they're a pain to pack and ship!
Re: Dye Sub Clock
Justin.... Pizza boxes :biggrin:
Re: Dye Sub Clock
Lol, boxes not a problem, keeping the hands straight during post is tricky.
Re: Dye Sub Clock
Izza boxes again :)
do you know this plasic, three leged thingy on the middle of the pizza? You can use that to avoid hands squashed. And bit of coam under hands for more security :)
job done!
Re: Dye Sub Clock
I tend to put foam over the face and cut slots out for the hands to sit in but it's a faff.
