Does this remove vinyl from clothing?
Dave271069
Re: Does this remove vinyl from clothing?
Post by Dave271069 »
https://shop.ralawise.com/products/4885 ... Term=vinyl remover just wondering if this will take off vinyl from polos?
arko
Post by arko »
Klebstoff is glue in German so it may well remove it. I didnt look at the whole ad but if you mail the firm, Im sure they will be able to inform you. Also that way if they say "yes it will remove it".. and it doesnt, Im sure that you can get a refund for being misinformed. Also, I saw this on Xpres. ... http://www.xpres.co.uk/p-7646-transfer- ... 400ml.aspx
Used the Xpres one in the past....life saver!
polish remover :)
works good on flex :)
Bear in mind that depending on the vinyl you use it can sometimes leave a ghosting where the adhesive was. Best suited where you can put vinyl over the affected area again to cover :-)
logobear
Post by logobear »
Quote "polish remover :) works good on flex :)"
what kind of polish remover - is there a brand?
Johnny
Post by Johnny »
We use the xpres remover. Though it doesn't work very well on anything other than the white and black superflex.
logobear;71021 wrote:Quote "polish remover :) works good on flex :)"
sorry. I cant remember the brand. I grabed what was in my wifes make jp box and applied with cotton bud to the beack of the tshirt. Glue side :). Then little bit on top. And it worked. This was tiny bit that i forgot to weed.
tlworkwear
Post by tlworkwear »
Paul;70988 wrote:polish remover :)
I second this! I just use a no brand from a salon supply shop I found and it works a treat. I'll try to dig it out a bit later and find out exactly what is in it.
JackB
Post by JackB »
Be careful how you use that stuff Paul, You being Polish and all that. lol
Jack.
