Does this remove vinyl from clothing?
Dave271069
Re: Does this remove vinyl from clothing?
https://shop.ralawise.com/products/4885 ... Term=vinyl remover just wondering if this will take off vinyl from polos?
Klebstoff is glue in German so it may well remove it. I didnt look at the whole ad but if you mail the firm, Im sure they will be able to inform you. Also that way if they say "yes it will remove it".. and it doesnt, Im sure that you can get a refund for being misinformed. Also, I saw this on Xpres. ... http://www.xpres.co.uk/p-7646-transfer- ... 400ml.aspx
polish remover
works good on flex
works good on flex
Bear in mind that depending on the vinyl you use it can sometimes leave a ghosting where the adhesive was. Best suited where you can put vinyl over the affected area again to cover
Quote "polish remover
works good on flex
what kind of polish remover - is there a brand?
We use the xpres remover. Though it doesn't work very well on anything other than the white and black superflex.
Day Out Photography
www.dayoutphotography.co.uk | facebook.com/DayOutPhotography | twitter.com/DayOutPhotos
m. 07817 118 717
m. 07817 118 717
sorry. I cant remember the brand. I grabed what was in my wifes make jp box and applied with cotton bud to the beack of the tshirt. Glue sidelogobear;71021 wrote:Quote "polish removerworks good on flex
tlworkwear
I second this! I just use a no brand from a salon supply shop I found and it works a treat. I'll try to dig it out a bit later and find out exactly what is in it.Paul;70988 wrote:polish remover![]()
works good on flex
Be careful how you use that stuff Paul, You being Polish and all that. lolPaul;70988 wrote:polish remover![]()
works good on flex
Jack.
