China mug oven wrap
epstnb
Re: China mug oven wrap
Post by epstnb »
Hi,
I bought an oven wrap to try out on some china mugs I have. Its a pain to do these in my normal mug press so thought I would try the oven method.
Anyway I got this from the Transfer Press and well check out the pics. Have I done it wrong ? Around the handle there is just a massive gap ! And it is a bigger pain in the arse to set up than the mug press.
It does fit snugly around the curved shape of the mug though.
I emailed them a few days ago but well I guess they don't wanna know , ha !
Anyone know of any alternatives that fit better around the handle ?
regards
[ATTACH=CONFIG]1738[/ATTACH][ATTACH=CONFIG]1739[/ATTACH][ATTACH=CONFIG]1740[/ATTACH]
vB_ID:1740
vB_ID:1740
vB_ID:1739
vB_ID:1739
vB_ID:1738
vB_ID:1738
Andrew
Post by Andrew »
It is put on wrong. Clasp should be the other way around but also not sure if the silicon is on the clasp correctly. Got some in work so can take a look in morning if you do not get it sorted before.
JMugs
Been thanked: 12 times
Post by JMugs »
Yep ass about face, and I can laugh because I spent hours (literally) with a bottle of wine trying to sort this sort of clasp out! Just put them on the other way around ..... have a bottle of wine first, it then becomes really obvious!
Janners
Renniwano
Post by Renniwano »
Not sure if this will help.. but this is how I close mine.. and it gives me a close to the edge finish.. not sure if it's actually 'right' lol
[ATTACH=CONFIG]1741[/ATTACH]
vB_ID:1741
vB_ID:1741
epstnb
Post by epstnb »
Andrew;69170 wrote:It is put on wrong. Clasp should be the other way around but also not sure if the silicon is on the clasp correctly. Got some in work so can take a look in morning if you do not get it sorted before.
I will try it the other way around in the morning.. mind you if the silicon is incorrectly on the clasp, i'm doomed ! .. even wine won't help me
epstnb
Post by epstnb »
Renniwano;69202 wrote:Not sure if this will help.. but this is how I close mine.. and it gives me a close to the edge finish.. not sure if it's actually 'right' lol
Thanks for sharing that. If i can fit mine like yours i will be happy.
cheers
Renniwano
Post by Renniwano »
No worries :)
If I do it any other way, it doesn't sit tight right up to the clamp ends..
epstnb
Post by epstnb »
Just to follow up.. I got the wrap to fit as per Renniwano's photo.
Easy when you know how !
Renniwano
Post by Renniwano »
Glad to have been able to help :)
