silhouette cutter
jennywren
Re: silhouette cutter
Post by jennywren »
viccar;66430 wrote:the lever on the right should point upwards
yes it up
after you've lifted the lever to move the rollers, are you closing the lever again before loading the mat? sounds like that might be the issue.quotespongerobinson
Yes I do that. thank you both of you for your rep leis , now I finally got it out I will not be giving up
viccar
Post by viccar »
The short line on the left is where you line the mat up to, so that both rollers should not be on the sticky bit of the mat, also are the rollers in the groove
Mat in arrow first.
Cant think what else would cause this.
maybe a photo of how youve loaded the mat
jennywren
Post by jennywren »
My first roller is right near the cutter, and it was a a4 sheet of card the other was on the card, I'll set the machine up tomorrow and double check. Thanks again
viccar
Post by viccar »
the other roller (white) shouldnt be on the card. it should be on the edge of the mat
viccar
Post by viccar »
[ATTACH=CONFIG]1581[/ATTACH][ATTACH=CONFIG]1582[/ATTACH]
Im hoping you can see these enough to make out the text it is a 12 x 12 mat i just squidged the photo to fit it in.
Also mat and vinyl with no mat should be lined up with the short line on the left.
I realy need to get a video, and could put a few cameo tuts on here.
vB_ID:1582
vB_ID:1582
vB_ID:1581
vB_ID:1581
jennywren
Post by jennywren »
Looking at the pictures I'm placing the mat by the second line. I'm of to work in a hour so that will be my first thing on my list to try again lets hope that sort my problem
jennywren
Post by jennywren »
Thank you viccar I used the marks that you gave and hay presto no sliding, so not sure what's next, but back to reading the manual and learning what comes next
viccar
Post by viccar »
Good glad you got it sorted,
i would reccomend an afternoon watching loads of youtube videos on the cameo, great way to learn it and the software, and gives you some inspiration as well.
jennywren
Post by jennywren »
Just using some card from the card shop to practise on, it the cutter always this loud, its not a quite machine. I suppose its its trial and effort getting the number right on the cutter for depth
viccar
Post by viccar »
if your using the studio software, then use the menu on the right when cutting as to what your cutting and it will tell you the blade depth,
if you use the test cut it will only cut a little triangle and you will see if the blade is right depth for the card without ruining it all.
better to start of shallow than the blade too deep if your not sure.
