silhouette cutter
jennywren
Re: silhouette cutter
Post by jennywren »
As it is quiet in the shop today I got out my silhouette cutter which I have never use, its been on my to do list before Christmas.
I'm ok till I have to put in the mat, I lift the lever and pop in the mat but when it starts to cut the mat moves around. tried it twice same results..Do you have to move the white roller( I think that white is the roller ) I cannot make them move no matter how hard I pinch them per instructions, as I missing something, that or I'm not strong enough
Ian M
Post by Ian M »
Jenny, this might be helpful for you to watch.
accdave
Post by accdave »
jennywren;66385 wrote:As it is quiet in the shop today I got out my silhouette cutter which I have never use, its been on my to do list before Christmas.
I've never got the pinch thing to work. Hold the silver bar with your fingers to stop it moving and then applying a bit of pressure twist and move the white roller out of the notches.
viccar
Post by viccar »
You dont lift the lever to load mat, the lever is used when you need to move the rollers.
you just put the mat upto the rollers,
rollers should be to the far right for mats, then select load cutting mat (if your using one)
That video is for the old silouett SD, i presume you have the new silouette cameo.
jennywren
Post by jennywren »
thanks Ian for the video, no it won't move, I have a very weak grip and and it new and not worn in yet. the air in my shop is blue lol but thanks for the advice
viccar
Post by viccar »
This ones for the cameo but turn the volume down first !
http://www.youtube.com/watch?v=CpRqEdJGEhE
jennywren
Post by jennywren »
I cannot shift the ... roller so I have phoned my brother who is built like a machine and will get him to twist it, once he moved it maybe it won' be so stiff, great video viccar. Will let you know how I'm getting on
jennywren
Post by jennywren »
I moved the roller in the end, it was stiff and very hard to shift, but the mat still moved, moving the roller made no difference any suggestions would be gratefully received. I had my meal so I going to look at youtube to see if I can find the answer there.
spongerobinson
Post by spongerobinson »
after you've lifted the lever to move the rollers, are you closing the lever again before loading the mat? sounds like that might be the issue.
viccar
Post by viccar »
the lever on the right should point upwards
