First Photo Slate what do you think??
marksbananas
Re: First Photo Slate what do you think??
Post by marksbananas »
if i print the image not using powerdriver it prints fine, its only when it is printed through powerdriver
FairyD
Post by FairyD »
Mark....have you printed it out on a normal printer?! Does the same thing happen on a normal inkjet!
It is a bit strange how it's concentrated on just one area....could it have been affected with moisture/glue or something!??!
I can try printing it out here if you want to send me it over see if I get the same result?!!?
marksbananas
inh photo shop i go to edit image size and put the size i want the image and make sure the resolution is 300dpi, the orginal is 72dpi, but even if i dont effect the dpi and leave it at the 72dpi it prints the same i have unistalled all driver and reinstalled and as long as i dont print in pwerdriver it is fine, not sure but think there is something with a setting somewhere but i cant find where
marksbananas
FairyD;65374 wrote:Mark....have you printed it out on a normal printer?! Does the same thing happen on a normal inkjet!
I have printed on normal paper through a normal printer and its fine, the paper image out of the ricoh even has the blocks on it i ahev attached the image of the paper out of the ricoh, normal printer has been fine
vB_ID:1550
vB_ID:1550
photo paper.jpeg (99.09 KiB) Viewed 415 times
marksbananas
found the problem turned off colrsure and its fine
marksbananas
the image doesnt come out as well now though when pressed the first one with the blocks was really glossy and had a nice look this one without the colorsure on comes out quite dull
marksbananas
any tips on how to get it glossy, my first one came out glossy but now i have solved the problem it is coming out the press matt finish
marksbananas
Been testing all day and been to asda and got thinner backing silcone sheet and still the image comes out on the slate as dull matt finish, i must be doing something worng but i have tried all day with diferent settings and still comes out dull and matt, first one i ever did was nice and glossy but not had that effect since really going round in circles now
Not sure how much difference it makes but I print mine with a felt pad on top not silicon.
marksbananas
yeah i have treid alsorts, the print comes out the printer should it be quite faint or strong image? as mine are coming out quite faint
