blacks gong brown again
Re: blacks gong brown again
on a pic someone sent in for an iphone case.
blacks going brown - to much heat ? or to much time ? - to much pressure ? or a crap pic ?
off to try again :rolleyes: - prob them all lol
here is the original pic from customer -which has been cropped and brightened up, cause it was really dark
http://i1264.photobucket.com/albums/jj4 ... cdc1c4.png
and heres what the thing is turning out like
http://i1264.photobucket.com/albums/jj4 ... 9db5b6.jpg
have tried lowering temps, less time, less pressure, nothing.
black come out fine on mugs
- Has thanked: 11 times
- Been thanked: 9 times
If you're using a Ricoh I'd say it was too much heat and/or time. What settings are you using?
ha - wished i was justin - brother 5910dw :rolleyes:
temp -180 -time - 180 - presure -heavy
tried temp-175 - time - 175 - med pressure - still same
blacks come out fine on my mugs -so inks are ok
the first setting has worked fine for all other colours - bar tonight with the black
edit -
doing a colour chart test on one of my mugs - to see if it is the ink, or printer needs re-profiling again.
post pic in 5 mins
edit -
post pic in 5 mins
had a 10oz in mug press - went to loosen mug press for the 15oz mug - dam thing fell apart :rolleyes:.
now need to wait till it cools before i can sort it -
coffee and some de-stress tabs
DF1 Press justin - just needs re tightened - just need to let it cool.....been here before and forgot it was that hot - OUCH !
right sorted - have down 3 rows of square, 6 across
first row - RGB
second row - CMYK
third row - PATONE
just to see what the colour difference is....
why patone ? i,m sure i down something with this and it came out better than expected !
first row - RGB
second row - CMYK
third row - PATONE
bigJ! your image is brown
not to much but i can clearly enough see that is lot of brown in it!
wait till you see the mug i just done....think i really need another profile -YIKES! - my ink is getting on for around the 8mth mark and if i remember right, JSR said he had to get his redone as the composition of the inks change with age
uploading to photo bucket now..hold on guys
try to press this one on other side of the mug
